stevej
Member Since 11 Feb 2006
Offline Last Active Nov 27 2010 01:31 PM
In Topic: Kenmore side-by-side refrigerator model 596.50694001 about 9 yrs old
23 May 2009 - 04:16 PM
Thanks very much. I don't see any fuzzy ice on the back wall. I'll try to remove the back panel and post a picture.
You ask if the condenser fan is running. How would I tell? If it weren't, wouldn't the freezer be well above freezing?
In Topic: kenmore washer whining model 23012100
06 February 2007 - 04:10 PM
Thanks for the suggestions. It sounds like i need to poke around a bit, or else just wait for something to fail outright.  I think i'll let the noise get a little worse before I start poking.
In Topic: dripping cold water dispenser
25 February 2006 - 05:15 PM
thanks, you were right. If I'd had the sense to use a flashlight i'd have seen it straight away.
I got the "secondary valve", replaced it, and problem solved.
Thanks Samurai forum and all those who offered their suggestions! This is a terrific site.
14 February 2006 - 06:15 PM
Thanks. I will try that, but are you sure it's the bottom panel -- i'm not talking about the first solenoid connecting directly to the outside water line, its the second solenoid which is after the water filter.
I appreciate the advice.
14 February 2006 - 06:06 PM
Having found a diagram on the sears parts site, i see that there is indeed a second solenoid valve beyond the water filter. This is probably what needs replacing.
Does anyone know how difficult accessing this component is? I'd appreciate any instructions.
Thanks
