kpool
Member Since 07 May 2009
Offline Last Active May 09 2012 09:55 AM
Subzero 590 refrigerator is warm, freezer cold but no ice
08 May 2012 - 08:10 AM
my subzero model 590, s/n 1315600 refrigerator side is warm-60 degrees. Compressor is running and condenser fan is running. Frig evaporator has no ice but evaporator fan does run.
I replaced the timer with no help. Interested to note-the timer has voltage at the plug but the timer does NOT ROTATE. The replacement timer is a Whirlpool 4391974 and the black jumper is attached to terminal # 2.
As for the ice maker, freezer temp is at 0 degrees. The ice shutoff arm was in the up position so I rotated the gear and the ice bin level arm moved to the down position but still no ice and it did not fill with water.
I appreciate any help you may offer.
Thank you,
Keith
Sub Zero Model 590 service manual
07 May 2009 - 08:54 AM
I am looking for a service manual for the Sub Zero model 590. Your assistance in pointing me in the correct direction is greatly appreciated. Thank you, Keith.
