chasimoto
Member Since 10 May 2009
Offline Last Active Oct 01 2013 12:50 PM
Aquastar 125 BO flue gas sensor
10 March 2013 - 08:53 PM
Anyone out there hazard a guess on this problem?
I've been through all the service bulletins for a non-working Bosch Aquastar  (AQ 125 BO), and have done all the tests I can think of, but still the pilot light won't remain lit. Thermo-couple is putting out about 25 mVDC, right in spec with what it should be, and that leaves me with only the flue gas sensor and the electromagnet assembly as possible culprits. I'm not sure how the flue gas sensor is supposed to work, but as it's sitting on the exchanger coils, I'm guessing heat either opens or closes the contacts inside, thereby making or breaking the connection from the thermo-couple to the electromagnet assembly. This unit sits dormant all winter, and has given me trouble before when getting it ready for use in the spring. At this point, nothing I do seems to be able to keep the pilot light lit, including jumpering out the suspect components (ECO, flue gas sensor).
I'm just about ready to remove the unit and scrap it. Any ideas out there?
Thanks in advance!
Chas
Replacement igniter for DCS 366
21 September 2012 - 10:07 AM
The broiler on our DCS RGT366L has quit working (suspiciously right after the tech rep replaced the oven igniter) and I'm trying to find the best replacement for it. Many thanks to all who have posted previously on DCS issues pertinent to our situation (delayed ignition, correct alignment of igniter in bracket, diagrams, service bulletins, etc). I see the oven igniter listed as an available part, but the one for the broiler doesn't seem to be mentioned. Anybody have any suggestions?
many thanks in advance!
