tinkertech
Member Since 12 May 2009
Offline Last Active Jul 05 2013 09:22 PM
In Topic: GE M#WSXH208V1WW Making Noise
05 July 2013 - 09:13 PM
Thank you so much for responding. Your info really helps out a lot. I wasn't able to get to it today , but have unit closed so I can inspect it tomorrow. With your input I feel confident about finding the problem. Again, thank you very much!!!
In Topic: Maytag washer Lat5005AAW
26 June 2013 - 10:11 PM
Thank you so much Eric for responding and explaining it so well.Now I can spend with confidence!!!
In Topic: Drum making banging noise in spin:Whirlpool WET3300SQ2
18 September 2011 - 10:03 PM
When I took pins out the washer banged more violently and shut down
In Topic: GE Fridge GTH18CCT3RWW how to get into defrost mode
17 July 2011 - 06:55 PM
Thank you for your response.This fridge is new and under warranty.I work at a resort and we are having a lot of trouble from our brand new appliances.Since their all warrantied it cost us nothing,but I've never seen this much trouble from new appliances in the past.When I found that this fridge had a defrost board instead of the old style defrost control,I didn't know if you could make the board advance to the defrost mode or not. It has a modular plug coming from the board with male ends,it may be a test plug but I thought I would ask here just in case.
In Topic: GE Dishwasher #GSD2100N10WW
25 October 2010 - 06:25 PM
Yes it is energized and opening
