gergrff
Member Since 29 Jun 2009
Offline Last Active Mar 29 2015 06:06 AM
In Topic: GE Monogram Oven model # ZEK756GP5BG bottom element stays red
17 April 2014 - 09:44 AM
Thanks for the help. I had checked the download section for a service manual or tech sheet. I did not find one for this unit.
GG
In Topic: GE Refrigerator Model # TFX 25 JRYF - Ice at drain hole
11 February 2014 - 01:39 PM
I replaced the defrost thermostat and defrost heaters. Everything is working fine with no ice build up at the drain hole.
GG
31 January 2014 - 06:30 AM
Olyteddy,
Thanks for the response to my question. I appreciate your help.
GG
29 January 2014 - 05:34 PM
I appreciate the reply.
I wanted to blame this problem on the defrost heater(s) or the defrost timer.
If the unit only has one defrost heater - Will it be apparent where to install the second one? Hopefully, there will be instructions with the kit.
Thanks for your assistance.
GG
29 January 2014 - 10:04 AM
Thanks for the reply.
I checked the door gaskets - everything looks good and it is sealing properly.
Seems like it is the condensate that comes off the evaporator coil during the defrost cycle. Looks as though it builds up over a period of time. It forms a block of ice that becomes taller than the ledge, and then the ice forms a trail under the bottom basket.
Would appreciate any ideas!
Thanks,
GG
