gergrff
Member Since 29 Jun 2009
Offline Last Active Jun 25 2015 12:02 AM
#284221 GE Refrigerator Model # TFX 25 JRYF - Ice at drain hole
Posted by gergrff on 11 February 2014 - 01:39 PM
I replaced the defrost thermostat and defrost heaters. Everything is working fine with no ice build up at the drain hole.
Thanks for the help.
GG
#249043 Kenmore washer model #110.4646250
Posted by gergrff on 25 February 2013 - 03:47 AM
Thanks for all the help.
jb8103, thank you for your offer to help with a free diagnostic call.
I replaced the main control board and the pump. The machine now works just fine. As it turns out the main control board was flaky - on several test
runs, the machine forgot to spin. I decided to replace the pump, because the old one pumped, but sounded bad after it ran for a while.
GG
Motor control board ==> http://www.repaircli...er=110.46462500
Main-Control-Board-W10273502-00688091.jp
Drain pump ==> http://www.repaircli...0130913/1373005
