gergrff
Member Since 29 Jun 2009
Offline Last Active Yesterday, 10:38 PM
GE Monogram Oven model # ZEK756GP5BG bottom element stays red
16 April 2014 - 10:48 PM
The bottom oven gets too hot and the bake element  stays red after preheating.
Is there a repair manual available for this oven?
What should I check first?
Thanks for any assistance with this problem.
GG
GE Refrigerator Model # TFX 25 JRYF - Ice at drain hole
28 January 2014 - 01:07 PM
This refrigerator seems to be working fine except for the ice build up at the drain hole in the freezer. I have melted the ice at the drain area and down the tube twice. I have verified both times that the tube is
completely open. Since this ice builds up over time, a few drops of water end up on the floor - near the
left side under freezer door.
Could the defrost timer be malfunctioning and cause this problem. I would appreciate any ideas.
Thanks,
GG
Kenmore Washer model # 417.48112701 wet clothes
18 July 2013 - 06:39 AM
The clothes intermittently come out of this washer wet.
I have tried the simple things - How would I decide whether it is the main
control board or the motor control board?
Any help will be appreciated.
GG
Whirlpool WFW8300SW04 - Door seal leaks
08 July 2013 - 03:37 PM
What is the correct way to replace the rubber door boot (bellows) on this machine. Do I need any other
parts besides the W10111435?
Kenmore washer model #110.4646250
09 February 2013 - 05:06 PM
I need some ideas about what to check on a Kenmore washer model # 110.4646250 that leaves the clothes wet - I don't
know if it is not draining properly or not spinning properly.
Is there a service manual available for this unit?
Any help is greatly appreciated.
GG
