J5
Member Since 12 Jul 2009
Offline Last Active Jul 03 2015 03:16 AM
In Topic: Fisher Paykel DD602 will not start
03 July 2015 - 03:19 AM
broken door switch , the beeps are telling you the door isnt closed
check the service manual on replacement
In Topic: Got my AllDolly
29 June 2015 - 11:32 PM
repair ? prob not but if you were doing install jobs it would be useful
In Topic: Can anyone confirm I have bad motor?
29 June 2015 - 11:30 PM
f&p dryers use caps
along with some others here down in aus
most common dryer job i do here prob 75% of them
In Topic: Bosch dishwasher
26 June 2015 - 06:29 PM
1st thing dishwasher does is run the drainpump
since the water isnt going out then 1st check would be for blocked drain pump or drain point
can you hear the drain pump running or a dull humming ?
if it cant drain out then it wont go to fill
In Topic: Transported freezer chest on its side
26 June 2015 - 01:44 AM
you can transport on the side but you need to pick your side
looking at the compressor there is 2 pipes that lead off to the system and on the other side you get the one sealed off pipe that was used to fill the system originally
you need to put it on its side so the 2 pipes are up so that the oil wont travel into the system and fill the dryer
if you go this you really only need 5 mins for the oil to settle back in the bottom of the compressor
