Member Since 08 May 2005
Offline Last Active Apr 09 2015 07:35 PM
In Topic: Eletrolux EW30DS65GS7 dual fuel oven F10 runaway temp
08 April 2015 - 11:47 PM
You may not need the board, check on the back of the oven (from the rear (cover removed) the small wiring running to the temp sensor had a small thermostat in the circuit, which has a small red reset button on it. This thermostat may have tripped during a clean cycle or long bake cycle.
In Topic: Bosch SHX46A05UC/30 does not enter cycles
05 April 2015 - 12:12 AM
How do you know it heats? Shouldn't heat unless water is flowing through the circulation pump as it activates a heat switch.
In Topic: Hook up RO system to regular faucet?
05 April 2015 - 12:06 AM
It is conditioned (softened) water that is caustic to metals (eg water heater) - RO water should not be an issue. You cannot share the dispenser faucet with the raw water faucet as that would defeat the purpose, how would the faucet determine whether to allow RO water or raw water to flow?
In Topic: Samsung RM255lashp Section designations
04 April 2015 - 11:56 PM
No, the missing segment of the digit is actually the failure code - you need to get the mfrs diagnostic info to decipher (or a model with same control)
In Topic: Old Skol Whirlpool LAF5500W1 washer rebuild
04 April 2015 - 11:37 PM
Aarrggghh! Can't seem to edit my post from my mobile device, the above line about the transmission shaft should read " let's the shaft drop too far". The 285203 beg kit is for the portable machines, 285134 is for all the others. Also it is normal for the trans to drip while the machine is tipped over because there is a vent hole in the case.
I have rebuilt way more of these machines than I could care to admit to, brings back many memories of a much better time.
