Member Since 08 May 2005
Offline Last Active Apr 09 2015 07:35 PM
#186783 LG Dryer DLE2514W Does not spin
Posted by kdog on 16 February 2011 - 11:47 PM
think that has anything to do with it-meaning the vent hose has changed position.
Quite possibly, try it for a bit with vent disconnected and see what happens
#185683 Maytag Neptune MAH8700A - E3 Error Code
Posted by kdog on 06 February 2011 - 11:53 PM
The load was ONE pair of jeans and one piece of underwear -
This could be at the root of your problem, too small a load such as this will simply ball up on one side of the tub and create a "catapult" effect, the motor only sees sharp thrusts of tourque and interprets it as an off balance situation, stops spinning and logs an error. Loads should be full loads of similar type materials
#183023 Maytag MLE2000AYW does not spin
Posted by kdog on 13 January 2011 - 03:40 PM
Yep, Lifetime Warranty on those transmissions
Might be needin' this:
http://www.repaircli...mber=MLE2000AYW
#182350 Bosch Apexx SHV99
Posted by kdog on 08 January 2011 - 05:54 PM
Is there more to that model # ? I can't find anything on SHV99, as a rule, they are longer than that
For manuals and lots of other goodies, become an Apprentice==> http://appliantology.org/apprentice/
#180825 Asko T760 dryer help
Posted by kdog on 23 December 2010 - 10:56 PM
You'll need one of these:
Click onPic
Measure the Element continuity to ground
#178499 Root Kill Question
Posted by kdog on 03 December 2010 - 03:55 PM
I believe the proper procedure is to remove the tree and replace the damaged sewer service line :mellow:
#149940 retrofit gas oven?
Posted by kdog on 17 April 2010 - 08:17 PM
Since the valve in the piloted burner is an on/off affair, how would you cause the introduction of gas to delay until the ignitor glows up, the valves in the hsi systems are bimetal, which open slowly to allow for this, also there may not be a proper air/fuel ratio to cause proper ignition, my guess would be that it can't be done - likely, you could repair your "wonky flame switch" by cleaning out the pilot tube so that it engulfs the flame sensor properly - this may solve your dilemma
#143566 any Rat stories out there?
Posted by kdog on 28 February 2010 - 06:55 AM
Them wouldn't happen to be Aphganistan Rats, would they?
#127834 Digital multimeter recommendation?
Posted by kdog on 08 August 2009 - 07:42 PM
One word: FLUKE
