FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
Member Since 08 May 2005
Offline Last Active Dec 24 2013 06:42 AM
#208561 Lennox G8D2-82-3 Furnace
Posted by kdog on 20 September 2011 - 12:07 AM
If the thermocouple were bad, the pilot would go out - that's an old draft furnace like mine with a cast iron heat exchanger - parts inavailability will be the demise of these - if it's not coming on, see if someone hasn't shut off the switch (follow the powerwire), or a wire has come off the transformer from the thermostat (some thermostats have heat/cool switches inside them)
#208553 Samsung Washer WF206BNW/XAA
Posted by kdog on 19 September 2011 - 08:03 PM
Ok having a hard time getting a part number
Part link for the drain pump ==> http://www.repaircli...100054A/1534541
#208543 Whirlpool WFW9200SQ02 - Just beeps on power up
Posted by kdog on 19 September 2011 - 07:24 PM
I have a suspicion that you will be plunking, Slaw
#208542 lg dryer dle7177wm shorted out...
Posted by kdog on 19 September 2011 - 07:23 PM
Is there a way to test the mainboard?
Yes, test the power at the wires going into the board from the powercord - if you get 120 volts to the board, its bad
#208540 GE gts22kcmbrww goes warm then cold every 24 hours
Posted by kdog on 19 September 2011 - 07:15 PM
OK so now you need to determine wether there is 120 volts being sent to the compressor wires at the time it is refusing to run, if not - Controller; If you do have 120, then you likely have a bad start relay
http://www.repaircli...er=GTS22KCMBRWW
#208466 Whirlpool WFW9200SQ02 - Just beeps on power up
Posted by kdog on 19 September 2011 - 12:41 AM
#208458 Whirlpool DU1145XTPQA dishwasher noisy and clean blinks
Posted by kdog on 18 September 2011 - 11:31 PM
I will check the appliance store in the morning and see if they have it in stock,
Why Yes, yes we do ...
http://www.repaircli...ber=DU1145XTPQA
#208388 One down next problem Leak from bottom Pan MDB4000AWB
Posted by kdog on 18 September 2011 - 01:29 AM
You might be able to harden up on the plastic element nuts enough to stop the leak, but it's simple enough to just remove the element and put new seals between tub and element
http://www.repaircli...mber=MDB4000AWB
#208256 Whirlpool DU1145XTPQA dishwasher noisy and clean blinks
Posted by kdog on 16 September 2011 - 12:51 AM
Model Number ???
#208199 Kitchen aide KSCS25FKSS01 Ice chute Door not closing all the way
Posted by kdog on 15 September 2011 - 02:11 AM
Depends if the doors pivoting pins are still intact - if so, the first kit'll do ya
If one of the pins has bust, then you need the second kit with the metal plate
#208198 GE top freeze TBX20PG Freezer PRETTY cold, refrigerator warm
Posted by kdog on 15 September 2011 - 02:07 AM
That system will NOT be R-22, it is definitely R-12
#208195 KM (WP) 110.66852694 starting itself
Posted by kdog on 15 September 2011 - 01:26 AM
Any instances of KM (WP) clothes washers 110.66852694 starting themselves?
Only when, in fact, they are a Dryer
http://www.repaircli...er=110.66852694
#208112 Whirlpool Ultimate Care Heavy Duty - Super Capacity Plus Washer LSR8233EQ0
Posted by kdog on 13 September 2011 - 10:30 PM
Here at Appliantology.Org, we do all the legwork for you - just click on the Partlink to order up the part and sit back and enjoy the enclosed help video - you get the easy task, which is to put the part in - We could charge more for that, but we don't ....................
http://www.repaircli...285753A/1195967
#208111 Range Won't come out of Sabbath Mode agr5735qdb
Posted by kdog on 13 September 2011 - 10:22 PM
If you press "Cancel" and "Cook and Hold" simultaneously for 3 seconds it will enable/disable the Child lockout feature Which results in the displays and locking that you describe - Could be that cooking grease vapors have invaded the touchpad and is causing shorts in the keytails
16022498
Become an Apprentice Appliantologist and Enjoy Special Perks
#208034 Frigidaire front load won't final spin
Posted by kdog on 12 September 2011 - 11:55 PM
No tech sheet on behind bottom front panel... :(
I wonder what happens to all those "missing" tech sheets - only ones I ever saw missing were the ones that were "taken" - must be those Gnomes again :kopkrab:
