Member Since 08 May 2005
Offline Last Active Jan 12 2015 10:39 PM
#208034 Frigidaire front load won't final spin
Posted by kdog on 12 September 2011 - 11:55 PM
No tech sheet on behind bottom front panel... :(
I wonder what happens to all those "missing" tech sheets - only ones I ever saw missing were the ones that were "taken" - must be those Gnomes again :kopkrab:
#207489 Lost Necklace in Washer - Whirlpool TAWS800JQ0
Posted by kdog on 06 September 2011 - 08:57 PM
May have found it's way into the drain pump where it awaits you to unwind it from around the impeller, or it could be laying in outer tub below the basket
http://i160.photobuc...ers/wpwash1.jpg
http://applianceguru...forum2/141.html
#207485 FIX for Slow Condenser Fan 2001 GE Arctica Refrigerator, model: psi23ngmbb
Posted by kdog on 06 September 2011 - 08:25 PM
Or, just play it safe and get a new fan motor
http://www.repaircli...ber=PSI23NGMBBB
#207399 WP washer M# WTW6200VW0 leaking
Posted by kdog on 06 September 2011 - 12:18 AM
There was an update to the tub ring at some point to prevent leaks at front, left corner - i got fooled by a rolled up candywrapper in the fab. soft. port of the dipenser once - see this teardown :
http://appliantology...ytag-bravos-he/
#207398 Kitchenaid Ice bin will not seat in Refrigerator door-KSRG25FVMS00
Posted by kdog on 06 September 2011 - 12:13 AM
Just need to either turn the coupling a bit by hand, or close the door and press the lever for some crushed ice as it will advance the motor a tad
#207397 FP DD603 top drawer problem
Posted by kdog on 06 September 2011 - 12:07 AM
Make sure the "Y" connector at the end of the drain line has not collapsed as it can drain into the unused drawer if allowed to sag
#207392 Maytag Atlantis MAV6260AWW Washer
Posted by kdog on 05 September 2011 - 11:41 PM
Hello, Newman !
#207391 Miele w4840 Washer Customization
Posted by kdog on 05 September 2011 - 11:33 PM
You should not change the Country of origin as those Countries also use 220V, 50 Hz. supplies - Miele Technicians carry the Interface Rig
All of the adjustments can be made by manual input, unless programs have been reflashed from factory ($$$)
Those heaters, being 120V, are not nearly as effective as the 240V predecessors (or the smaller versions)
P/M'd 2 other documents (which are now in "Kool Stuff")
#207212 Problem with Icemaker 106.50592003
Posted by kdog on 03 September 2011 - 08:09 PM
You can test the valve by energizing the coil with a cheater cord (this is done behind fridge), no voltage across V-N is inconclusive; Measure Line(L) - V (Valve)
Icemaker sends power to valve, if no power = Icemaker if power but no water = Water off or bad Valve
http://www.repaircli...er=106.50592003
#207192 Dishwasher refills wihle draining or drying DWU7402AAB
Posted by kdog on 03 September 2011 - 06:47 PM
00748556.jpgIf you are certain the knob is not stripped, or has somehow been forced on 180 degrees outta whack - it can only be the timer
http://www.repaircli...8555&locID=2487
http://www.repaircli...mber=DWU7402AAB
#207128 Kitchenaid Glass Cooktop KECC562 Burner not working
Posted by kdog on 02 September 2011 - 02:14 PM
Gonna need to Lift the unit out of the Cubby, remove the knobs and screws around the outer perimeter and lift the glass top off to access components
Could be that one part of the element has failed, or the switch that controls it - elements can be ohm'd out
Click on Part Links to Order:
http://www.repaircli...ber=KECC562GWH3
#207127 Kenmore refrigerator 596.76592600
Posted by kdog on 02 September 2011 - 01:57 PM
Jam the fanblade before you turn the fridge on - then you can feel/hear only the compressor
#206840 frigidaire washer LTF2940ES1
Posted by kdog on 30 August 2011 - 10:45 PM
could that be a pump motor jam or bad pump motor??
Yes, if nothing is jamming the pump impeller, then the pump is shot
Make sure you check inside this as it is often full of goodies:
AKA - "Crap Trap"
#206817 frigidaire washer LTF2940ES1
Posted by kdog on 30 August 2011 - 07:19 PM
Ye olde crap trap enema. :dude:
Sounds like an important medical breakthrough, you awtta patent that like the Vulcan Lip Lock
#205811 Kenmore Dryer 110.73942101 - no heat
Posted by kdog on 17 August 2011 - 11:36 PM
Classic symptoms of a bad coil on gas valve, they come in a set (help video in link)
http://www.repaircli...Set/279834/3479
