Member Since 08 May 2005
Offline Last Active Sep 12 2014 10:34 PM
#205436 Food grade high temperature tubing for hot water dispenser
Posted by kdog on 14 August 2011 - 12:04 AM
Maybe :
http://www.repaircli.../8204511/909652
Generically Speaking, of course
#205289 Kitchenaid KSRL25SSFT SxS Refrigerator - repeated ice maker module failure
Posted by kdog on 11 August 2011 - 07:52 PM
I I have to push in the door switch once or twice and then it starts working.
Perhapsk ya gotsk yoo a bad Door Switchsk
http://www.repaircli...er=KSRL25FXBL00
#205219 Kitchenaid KSRL25SSFT SxS Refrigerator - repeated ice maker module failure
Posted by kdog on 10 August 2011 - 09:09 PM
More on that here: http://fixitnow.com/...ice-idi-system/
#202827 Dishwasher power cleaner (Whirlpool)
Posted by kdog on 15 July 2011 - 10:24 PM
This stuff works pretty good:
#201801 Bosch Dishwasher SHU43C05UC/17
Posted by kdog on 05 July 2011 - 10:20 PM
Sounds like a common failure in the heating relay on the controller - to link you to the correct one though, also need the 2 digits that appear after the uc - ex. uc/14, uc/17.uc/22 etc
#193255 "Vote Up" Not Working
Posted by kdog on 22 April 2011 - 10:32 PM
I don't believe those have ever worked as I always got the same message - probably connected somehow to the "reputation" of the user
#189135 Understanding Tech Sheets
Posted by kdog on 08 March 2011 - 01:42 AM
Can I hear an, "Amen?"
How 'bout a "Hello Newman !"
#188752 GE Bottom-Mount fridge, #GDS18SBRARSS, same problem 3x this year
Posted by kdog on 04 March 2011 - 05:17 PM
You can't see the drain hole inside the fridge 'cause it's covered in ice - best bet is to let it thaw out, the outlet is that little rubber hose in the centre at the back of the fridge.
Somethings clogging that up - once you have defrosted it completely you can clean out the tube with a piece of wire or something - then verify it's operation by pouring some water through the drain hole that is located under the fan
#188668 LG refrigerator error code ER-DH
Posted by kdog on 03 March 2011 - 08:35 PM
Defrost termination is controlled a little different in these units, has a thermister and fuse in the "control" harness that attaches to the evaporator - if the sensor is failing it could throw a wrench in the wheel
http://www.repaircli...Harness/1462588
#188543 Frigidaire oven F30 error code
Posted by kdog on 02 March 2011 - 09:14 PM
These are resettable, they are wired in series with the sensor and trip out during self clean. Located close to the area where the probe harness passes through the liner at back of oven. If you reset it, it may (likely) trip again during next clean - has been an issue, have placed thin washers under mtg screws and instructed user to move range out a few inches prior to cleaning. This mostly 'cause I hate callbacks
#187408 Miele W1918A - notchy drum
Posted by kdog on 21 February 2011 - 11:43 PM
It has always been my experience that grooves made in shafts by lip seals render shaft surface unrepairable - it is likely that if you used the old spider, it would work fine for a period of time. I would replace the spider, but shudder to think of what that may cost
#187022 Maytag LSE7806ACE No Water
Posted by kdog on 18 February 2011 - 06:24 PM
I believe that, as a grasshopper, you may only post to your own threads - change that here: For Service Manuals and lots of other goodies, become an Apprentice Appliantologist==> http://appliantology.org/apprentice/
As I recall, these washers can be slid out of the cabinet a bit - you remove the screws at the lower front that allow the front panel to be removed.
The top can then be unfastened by a couple of srews and lifted up, you'll find the lid switch there (pic attached) - HOWEVER, the fuse is located on the side front of the inner cabinet where the wiring runs.
#186783 LG Dryer DLE2514W Does not spin
Posted by kdog on 16 February 2011 - 11:47 PM
think that has anything to do with it-meaning the vent hose has changed position.
Quite possibly, try it for a bit with vent disconnected and see what happens
#186620 SERVICE MANUAL FOR MIELE S7 VACUUM
Posted by kdog on 16 February 2011 - 12:09 AM
document sent
#185683 Maytag Neptune MAH8700A - E3 Error Code
Posted by kdog on 06 February 2011 - 11:53 PM
The load was ONE pair of jeans and one piece of underwear -
This could be at the root of your problem, too small a load such as this will simply ball up on one side of the tub and create a "catapult" effect, the motor only sees sharp thrusts of tourque and interprets it as an off balance situation, stops spinning and logs an error. Loads should be full loads of similar type materials
