clancy
Member Since 15 Jul 2009
Offline Last Active Nov 02 2012 04:01 PM
In Topic: GE Profile TFX25PRYD BB
02 November 2012 - 02:31 PM
NO I got the 120 with the valve wires connected it is a disconnect plug.
02 November 2012 - 12:50 PM
Yes I did say ealier there was water there that must have been residual water as there was no pressure. I Thought there was water before the door but no there is not
02 November 2012 - 12:19 PM
OK My bad thanks for the link I guess I needed to read the whole thing. I did check valve assembly when the unit is unplugged I and the dispense button pushed I get continuaty across the relay and with power on I get 120 volt out. I disconnected the water connection at the valve and I still do not get any water. I am going to get a new valve assembly unless someone has a better idea. I am thinking it is a mechanical issue with valve.
31 October 2012 - 07:21 AM
Thanks for the links I am thinking that this is not likely the problem as The unit was shut off and not even cold and I can not get water from the dispenser.
In Topic: Whirlpool Ice Maker ED5REXNl00 No Ice
23 July 2009 - 05:32 PM
Yes I put the jumper between T and H the cycle ran and water was allowed to flow to the icemaker.
