crosstalk
Member Since 20 Jul 2009
Offline Last Active Oct 16 2014 11:59 AM
In Topic: Samsung dryer DV419AGW/XAA noise
09 October 2014 - 12:29 PM
Thanks.  Seems like a pain to get to the rear ones, but I guess I have to do it.
In Topic: Liquid detergent cup on Samsung WF419AAW/XAA washer
11 December 2013 - 07:54 PM
Yes--it started recently so water temperature could be a factor.  Doesn't the machine add hot water even on a cold cycle to maintain a certain temp?
In Topic: Samsung WF419AAW/XAA draining problem
13 November 2013 - 09:23 AM
Thanks.  From other posts, it looks like I should have checked all the drain lines and the elbow in the line from the drum to the pump. Guess I will have to pull the machine out again--fun!  Seems like it might be difficult to remove the pump, but I am wondering if cleaning the check valve would help in case backflow is the problem.
12 November 2013 - 08:50 PM
Thanks. I removed the access panel in the back and removed the gray drain hose (hard to reach all the way up front when the pump is!). Very little water if any came out. Maybe because I drained the sump first. There was a some mildew gunk in the hose when I flushed it out, but no coins or obstructions. The outlet of the pump did not have an opening that I could feel with my finger. I guess it's a check valve. Should I check anything else? I just ran a rinse+spin cycle and it seems ok so the pump seems to be working at least most of the time.
12 November 2013 - 04:11 PM
Thanks--do I need to remove anything to get access to the pump outlet or just check the external tubing?
