Member Since 21 Mar 2005
Offline Last Active Today, 09:02 AM
#311548 Part number 8564137 for model GST9679PB1
Posted by Samurai Appliance Repair Man on 20 January 2015 - 08:51 AM
Does it add water any point in the cycle?
See if you're getting 120vac on pin 3 of the ATC switch with the washer set to fill. If you are, then the timer and pressure switch are good and the problem is the ATC switch. If not, and since you already replaced the pressure switch, then the timer is bad Part number: AP3175368
Tech sheet: Attached File  Whirlpool GST9679PB1 Washer Wiring Sheet - 8565442.pdf   650.61KB   4 downloads
#311509 GI5FSAXVY02 control not responding
Posted by Samurai Appliance Repair Man on 19 January 2015 - 06:26 PM
Thanks for letting us know!
#311470 DDG5780GDLWH GE Gas Dryer repair manual request
Posted by Samurai Appliance Repair Man on 19 January 2015 - 12:22 PM
Can't find the minimanual for your exact model but this one is probably close enough: http://appliantology...yer-minimanual/
#311463 WEE730H0DS0 --Slide in range with bad fan
Posted by Samurai Appliance Repair Man on 19 January 2015 - 11:45 AM
Once again, the schematic reveals all. The Hall Effect Sensor is shown as a separate part that's connected to P7 on the main control. Follow the wires and you'll find it. http://appliantology...and-tech-sheet/
I keep telling everyone that the schematic is the FIRST thing you go for, not the last!
#311404 Maytag Bravos XL Dryer Model # MEDB950YG Tech manual
Posted by Samurai Appliance Repair Man on 18 January 2015 - 07:02 AM
Mucho domos, Brother Appman!
#311353 Thermador Freezer T24IF70NSP/99 - Icemaker not producing Ice
Posted by Samurai Appliance Repair Man on 17 January 2015 - 06:43 AM
Mucho domos for the tech bundle, Brother Spanner!  :thumbsup:  :thanks:
#311201 Warm refrigerator troubleshooting quiz
Posted by Samurai Appliance Repair Man on 15 January 2015 - 10:40 AM
When you're ready to check your answer, click here: http://mastersamurai...-refrigerators/
#311196 About this Forum
Posted by Samurai Appliance Repair Man on 15 January 2015 - 10:27 AM
I'm posting the picture quizzes that I've been posting at my blog to this forum so they don't get pushed down and lost by new blog posts. Domos to Brother Durham for the suggestion.
If you know the answer or would like to comment or ask a question about the quiz, please do so at the answer link provided with the quiz. That way, the answer won't be right there in front of new eyeballs for others coming along who want to take the quiz.
Enjoy!
#311175 Samsung WF218ANW/X4A Won't Drain and Control Board
Posted by Samurai Appliance Repair Man on 15 January 2015 - 02:35 AM
I would still like to know how to enter the quick test mode so that I can continue troubleshooting ny nachine.
Glad you got it working!
The Fast Track manual shows how to do the quick test mode and other diagnostics:  http://appliantology...le-part-1-of-3/
You'll need to upgrade your membership to download it: http://apprentice.appliantology.org/
#311161 Frigidaire refrig. FGUS2642LF2 ice dispenser not working
Posted by Samurai Appliance Repair Man on 14 January 2015 - 05:12 PM
Does the augur motor stop, too?
Ice door gate control valve may be failing under load. Try hot-wiring that flapper solenoid and see if it stays open.
The gating for that flapper door is controlled by the dispenser control board. Have you changed that already?
#311124 Samsung Refridgerator RFG29THDRS
Posted by Samurai Appliance Repair Man on 13 January 2015 - 05:00 PM
Domo, Brother Spanner!  :thanks:
#311017 Kenmore dishwasher # 665.15892100- no water entering during washing cycle
Posted by Samurai Appliance Repair Man on 11 January 2015 - 01:45 PM
Thank you Samurai Appliance Repair Man.  As I mentioned yesterday, water is getting past the fill valve (which I called the 'water' valve yesterday) and is being sent in the plastic hose towards the heating unit.
Doesn't matter if you're not getting enough water, which Brother Chat's erudite question brought to light.
We've led you to the shimmering fountain of knowledge.  Now it's up to you to drink.
#311006 Back of dryer getting HOT
Posted by Samurai Appliance Repair Man on 11 January 2015 - 11:13 AM
Cost difference is about $20-- that's worth almost of a full minute of my precious time! :woot:  Consider the time savings of replacing the whole can vs. re-stringing is about 14 minutes, that's a $280 savings in my time right there.
#311003 Kenmore dishwasher # 665.15892100- no water entering during washing cycle
Posted by Samurai Appliance Repair Man on 11 January 2015 - 10:50 AM
You either have a gunked up fill valve Part number: AP3178609
or low water pressure to the valve.
#310944 Photo files to big
Posted by Samurai Appliance Repair Man on 10 January 2015 - 02:01 PM
Here's a help page from Microslop that might help: http://windows.micro...-a-jpeg-picture
