Member Since 21 Mar 2005
Offline Last Active Today, 08:50 PM
#223837 LG gas dryer DLG5988W Heat goes off after 10 seconds.
Posted by Samurai Appliance Repair Man on 13 February 2012 - 09:17 PM
Run the dryer on a timed heated cycle with the vent disconnected and a couple towels in the drum. Also, measure exhaust temperatures right at the exhaust port. Report.
#223781 Frigidaire PLD2560LCC1 dishwasher runs continuously - keypad doesn't work
Posted by Samurai Appliance Repair Man on 13 February 2012 - 11:54 AM
Check for 120vac between P1 and P3-7 on the main control board.
Did you do this check?
#223774 Gas Leak Detector
Posted by Samurai Appliance Repair Man on 13 February 2012 - 10:01 AM
Big Blu is the true goo!
#223755 GE front load whdvh626fww
Posted by Samurai Appliance Repair Man on 13 February 2012 - 12:58 AM
What did you end up doing to fix it?
#223749 Whirpool GHW9150PW0 washer dispensing the fabric softener during the wash
Posted by Samurai Appliance Repair Man on 12 February 2012 - 11:50 PM
Topic title edited.
Step C:02 in the diagnostic powers up the water distribution system so you can check the dispenser motor and switch.
You can also check the dispenser switch and motor at the CCU's dispenser wire harness connector. This cheat sheet will help you with that:
Whirlpool Duet Washer Component Testing
#223734 Samsung WF328AAW Front Load Leaking from Detergent Drawer
Posted by Samurai Appliance Repair Man on 12 February 2012 - 07:22 PM
Domo for posting the fix! :thumbsup:
#223731 Frigidaire Gallery Series GLTF2940FS1 Front Load Washer won't operate
Posted by Samurai Appliance Repair Man on 12 February 2012 - 07:15 PM
Sounds like the pump is hosed. Not uncommon to see that in these dinky pumps after when the gookus makes it past Ye Olde Craptrap and into the impeller ==> Drain Pump and Motor
#223730 Frigidaire laundry center FEX831CS0 washer tub leans badly
Posted by Samurai Appliance Repair Man on 12 February 2012 - 07:05 PM
Topic title edited.
#223610 Thermador MSC224 double oven: self clean doesn't work in either oven
Posted by Samurai Appliance Repair Man on 11 February 2012 - 02:52 PM
Remove one of the wires and check continuity across the terminals on the switch.
#223601 Thermador MSC224 double oven: self clean doesn't work in either oven
Posted by Samurai Appliance Repair Man on 11 February 2012 - 01:03 PM
That be the one. Use a better camera and post a bigger photo that's in focus so I can annotate it for you.
#223595 Kitchenaid (model KUPD01FLSS6) dishwasher will stop in mid cycle
Posted by Samurai Appliance Repair Man on 11 February 2012 - 11:28 AM
And to Mr Samarai, how can i check the water in the basin and the pump????????
Uhhh, lemme think about that one...maybe opening the door and looking at the water fill level????????????? :silly:
If it's filling, then put a glass in the upper rack right side up and let it run for 60 seconds. How full is the glass?
#223589 Thermador MSC224 double oven: self clean doesn't work in either oven
Posted by Samurai Appliance Repair Man on 11 February 2012 - 10:59 AM
Sounds right but why guess-- this forum as the capability of attaching photos to your posts. Do dat!
#223584 GE GLD5500L00WW Still Not right.
Posted by Samurai Appliance Repair Man on 11 February 2012 - 10:41 AM
...look at those connections in the junction box...
Right arm, Brother Kurtius. Coastie, those power connections could be loose making a flakey connection or they could be about to fo'shizzle:
#223550 kitchenaid dishwasher-upper spray arms not turning model KUDK03ITWH1
Posted by Samurai Appliance Repair Man on 10 February 2012 - 07:46 PM
#223546 Thermador Professional Range PGR486GL main oven won't light up
Posted by Samurai Appliance Repair Man on 10 February 2012 - 07:21 PM
The simmer controller and spark module are affixed to the inside of the LHS panel of the range. You'll have to remove the star burners for that side and remove that top panel to get at 'em.
