YasudaPlumbing
Member Since 25 Jul 2009
Offline Last Active Apr 13 2014 09:24 PM
In Topic: Icemaker no workee... Model # 253.7480240.
20 November 2011 - 04:56 PM
just an off the subject question but do y'all get a lot of sand and derbris in your water down there?
No, hardly at all. Most people drink the tap water here.
20 November 2011 - 04:53 PM
what's the Freezer temperature ?
Icemaker won't harvest unless freezer temp is below 17F.
Also check for fill tube freeze up, continuity in icemaker solenoid valve, and see if icemaker will run a manual harvest cycle.
After checking various areas in the freezer with a Fluke Infrared Thermometer, I got an average reading of ~0 degrees.
The refer is showing about ~40 degrees.
A close up visual of the fill tube looks ok (this is the tube that kinda looks like a chute). When I first installed the new IM, I did manually turn the motor to get it started. Then about 1.5 hours later I got my first batch of ice.
Where is the IM solenoid valve?
18 November 2011 - 02:12 AM
OK, guys.........new problem.
The IM is making ice, but not enough.
In 8 hours, I only have 2-3 batches of ice in the bin.
Could it be some sort of an adjustment problem?
16 November 2011 - 12:01 AM
I finally received my new IM from your website, installed it, and it works like a champ!!!
Much Thanks everyone! :thanks: :dazzler:
06 November 2011 - 05:53 PM
should be 120v AC between Black and Yellow at the IceMaker Harness Plug
OK, I went into the freezer, removed the IM and 4 pin connector.
Then checked for voltage at the incoming connector and I do have 120V at the yellow and black wires.
