court
Member Since 11 Mar 2006
Offline Last Active Jan 21 2015 03:39 PM
In Topic: Kitchenaide SM 8525121 over flowing
31 May 2011 - 06:40 PM
they are hard to clean.you need to take off the cabinet and pull inner tub.then it a matter of trying too clean the stuff out using water,air and small piucks
31 May 2011 - 01:09 PM
sometimes the box that water level hose plugs into on the side of the tub will get stuff in side it .as the water level goes up it will block the hose,when the water level drops it will go down and unblock the hose.the next time you use it,it may not block the hose,having you the on agin off agin problem
In Topic: maytag washer #lat9416aae
22 September 2010 - 01:08 PM
sorry it too so long to get back. itook apart.checked seal was flush and not damaged.wiped everything clean.put it back together.ran dry.put in loadand ran .water leaking down shaft on to transmission
21 September 2010 - 08:13 AM
filled tub with water.ran thru spin .no leak. put it all back together and thru wash cycle.no leak.put clothes in ran thru wash cycle.leaked .used MFG parts.could agitator be pushing on stem seal
In Topic: Kenmore Electric Dryer Series 80 Model 110.66812692
19 May 2010 - 09:28 AM
you could have a grounded heating element
