KFREED1871
Member Since 06 Aug 2009
Offline Last Active Jan 10 2015 03:22 PM
LG LRE30453 PCB REPLACEMENT
29 July 2014 - 10:16 PM
Range has a non functioning right front burner. Burner element ohms out within spec, and all wiring connections pass visual and continuity checks, so it should be a control board issue.
Replacement board has different part number than shown in service manual, so probably just an upgrade.
New board has identical molex and ribbon connectors in roughly the same positions,  BUT, the board also has what appear to be bake and broil power relays, ( there is a separate oven board in the range???) , and there are 4 male spades on the new board that I just can't make any sense of.
They are marked on both boards as tabs 9, 10, 11, and 12, but wiring the new board using the tab numbers from the service manual results in the right burner being powered on continuously, and not responding to the controls.
I don't have the option to test each potential configuration, since this range is in a rental unit, and the tenant is quickly losing patience.
Does anyone know the correct wiring for the upgraded board, and if so, would you please share?
Need a Service Manual for LG WM1814CW Washer, Please.
09 February 2013 - 03:23 PM
Need the service manual to enter diagnostic codes. Appears to be possible bad hall effect sensor, but since I repair appliances for a charity, ( Habitat for Humanity Restore) can't spend a penny more than necessary for parts. Thanks for your help.
SERVICE MANUAL REQUEST 106.59592990 fridge
30 April 2012 - 07:05 PM
If anyone has this, I would be most appreciative
Ken
