paulcoats
Member Since 09 Aug 2009
Offline Last Active Sep 22 2014 01:33 PM
In Topic: Water dispense hose on GE regrigerator loose
06 November 2010 - 02:47 PM
nevermind, found it. The tube was broken, the other end is behind the compressor. I probably need to get a new tube, right? Or can I patch the tube back together?
06 November 2010 - 02:45 PM
The tube comes out of a hole from the main part of the fridge that is behind and above the water valve.
06 November 2010 - 01:41 PM
No water at the dispenser, it just comes out of this hose.
In Topic: Oven not working on DCS Range
02 October 2010 - 10:29 AM
Thanks. One other quick question. The local appliance parts store says they have the ignitor. I called the DCS service department and they have the part and can ship it. Its about the same price for both with shipping. Do I need to be careful about getting the part from a local retailer?
02 October 2010 - 10:06 AM
One other thing. I just tried the oven again with the door and bottom panel removed. The gas came on after about one minute and the oven started. The gas seemed to die down a little after about 20 seconds but stayed on. One other thing, the ignitor stayed red hot even after the gas was on for a couple of minutes. Is that normal?
