paulcoats
Member Since 09 Aug 2009
Offline Last Active Sep 22 2014 01:33 PM
LG Washer WM1815 shuts off during wash cycle
19 September 2014 - 12:14 PM
This LG washer has been intermittently shutting off during the wash cycle over the last 2 weeks.  I checked the filter, ran the diagnostics and everything looks OK.  It will start the wash cycle, then in the middle of the cycle it just powers off completely.  The circuit is not tripped and it Powers back on without any errors.  I can sometimes just get it to start the cycle again, but sometimes when I try to do that the drum will start to rotate, and after about 3 inches of rotating it just Powers off again.  The spin only option seems to always work when it gets stuck like this.  The loads are small, its not overloaded.  I just bought a new LG WM3050 that is going to get delviered tomorrow, but debating whether I want to trya nd fix this one now.  Any ideas?  Is this something easy to fix?
Water dispense hose on GE regrigerator loose
06 November 2010 - 09:34 AM
I have a GE profile arctica side by side refriegerator model # PSH23SGNAFBS that has a disconnected hose near the water valve.   There are 2 white/clear hoses that come down from inside the fridge from a hole above and directly behind the water valve.  One hose loops under the valve and connects to the bottom part of the blue part of the valve.  The other hose is disconnected.  When I use the water dispenser water flows out of this hose.  I have the service manual but I cannot see where this hose connects to .  Where does it go?  See attached for a picture of the hose.
Oven not working on DCS Range
28 September 2010 - 11:25 AM
I have a 6 year old DCS range and the oven bake is not working correctly.  When I turn it on I get a faint gas smell and eventually after 15 minutes I usually start getting some heat.  It will reach the desired temperature but then starts to lose temperature and wil not re-ignite.  It used to sometimes work OK.  Most recently it does not work at all, or always heats up but does not re-ignite not at all.  the broiler seems OK.
The problem seemed to start happening after I remodeled our kitchen and had to lift the range a little to get the floor under the front legs.  I did not move the range too much, just had to relevel.  It is almost perfectly level (maybe off a few millimiters).  I am going to try and re-level, could this be my problem?  Or is it more likely a different problem?
Kenmoer Elite steam dryer
04 February 2010 - 02:38 PM
I found a Kenmore Elite Steam Dryer model 68062 on Sale at Sears Outlet for $450.  50% off.  Is this a reliable model?  Anyone have any feedback feedback on the "Steam" setting, does it really help with wrinkles (I hate ironing)?
 Anyone aware of any issues with this model?  I tried to look for any forum posts and did not see much.
They want $150 for an extended 3 year warrantly.  I know these are typically not worth it, but any advice on that?
Water damage from leaking GE profile arctica refrigerator model #PSH23SGPA
29 December 2009 - 09:48 AM
We just had our laminate floor ripped out of our kitchen by our insurance company due to water damage caused by a leaking GE Arctica regrigerator.  We noticed the warped floor boards on X-mas eve and after removing the back panel of the regfrigerator we spotted the leaking water from the water valve area at the bottom left of the refrigerator.  The leak was a very fast drip, almost a stream from the valve area.
The insurance company said I should keep any parts I replace on the fridge and they might try to recover some of my $500 deductable for the floor replacement.
We had a service person come out 6 months ago to replace the motherboard, and now this.  The refrigerator was 2 months past the extended warranty period when the motherboard failed.
Any idea on what might have failed to cause teh leak?  I have a service manual for the fridge but it does not say anything about a leaking valve/hose.  We had not moved the refrigerator since the last repair 6 months ago so I am not sure how the valve or line could have failed.
Any idea if GE might cover any of the deductable for the water damage?
