KurbyMstr
Member Since 17 Aug 2009
Online Last Active Today, 09:19 PM
In Topic: Fridge flow chart question
01 July 2015 - 10:21 AM
Dirty coils would make both sections warmer, but it would be a gradual.  It usually isn't enough to stop the unit from freezing items unless it is completely blocked.  However, with it being dirty it causes the more heat to be generated and if it goes on long enough it can cause a compressor relay to fail, or damage the compressor itself.  The condensor coil doesn't need to be spotless when cleaned, but it does need cleaned on a regular basis.
In Topic: KitchenAid KSCS25INSS01
02 June 2015 - 09:32 PM
Thanks for the responses.  I was able to run the service model.  Defrost heater did cycle on, Bi metal was closed and then opened- checked before and after defrosting evaporator.  I like the 2 year warranty that fixyourboard.com offers, repair is a little pricey but good warranty.
In Topic: Samsung RS263TDRS side by side
19 April 2015 - 09:02 PM
Where can I find an exploded parts view that shows the sensor locations so I know which ones I'm ordering. Parts select shows and exploded view, but not the sensors.  Repair clinic shows the parts, but not the location.  Sorry for being a pain, just trying to be thorough.  I do appreciate all the help and input from everyone.
18 April 2015 - 12:06 AM
Thanks again for all the feedback. I think the power cord is about the only thing that this refrigerator has in common with others. I will let you guys know how it turns out.
17 April 2015 - 05:23 PM
Ok, what would cause the board to stop sending power to the condesor fan motor if there is nothing blocking it?
