Anytime Nick
Member Since 08 Sep 2009
Offline Last Active Yesterday, 06:08 PM
In Topic: GE PFSS6PKXBSS WATER LEAK
16 May 2015 - 04:43 PM
This is a Samsung-built GE. They are pretty notorious for the fresh food defrost drains freezing up. I like to replace the Samsung heat probe with the Whirlpool part #Part number: 819043
Part number: 819043
In Topic: Kenmore/Whirlpool 26_26882_500 Top Washer 2nd Rinse/Spin
01 May 2015 - 06:52 PM
If it only has a little water from soaked clothes not spinning out, sounds like a clutch.
In Topic: Something stuck in between drums of a frigidaire affinity washer
01 May 2015 - 12:47 PM
If it is clothing of some kind you should be able to find it by shining a light thru the tub... Use a metal hanger or something to stick thru the perforated tub to hold it, and turn the tub til you work it down to the bottom of the tub. Then you can just take off the hose and grab it.
In Topic: Whirlpool SxS refrigerator GC3SHEXNT04 how do I get to the dispensor motor?
27 April 2015 - 06:42 PM
http://c.searspartsd...12037-00005.png
IPL for that model number shows the cover (#33). Whirlpool does have some models where the motor is accessed from the front, but this doesn't look like one of them from what I can see.
27 April 2015 - 04:13 PM
The motor should be accessible after removing a cover that sits on the bottom of the bulge on the inner part of freezer door / top of first storage compartment below the bulge.
