chrisabaker12
Member Since 21 Sep 2009
Offline Last Active May 18 2015 11:16 AM
Kenmore over 790.42003605 cannot calibrate potentiometers
03 April 2015 - 05:44 PM
Trying to repair a kenmore pro oven. Model 790.42003605. Serial nf3826056.
When we try the procedure to calibrate the potentiometers the temperature gauges will not respond. We have tried replacing the analog board, potentiometers, relay board, temperature guages, and the display board. the temp guages never move. When we get to the point where you adjust the guage to show 200 it doesn't move and when we push the up button it beeps and 11 flashes on the display, the down button shows 42 and the guages do not move with either button. Any help is appreciated. We have the tech sheet that comes with the machine. The service manual has been requested in the manual request forum.
Thermador wall oven MEM301ES/01
19 January 2015 - 12:28 PM
We are having trouble getting all of the "buttons" to resopond on a thermador wall oven
model number MEM301ES/01.  We have installed two interface boards and some of the buttons are not working well.  Some parts websites are showing a service bulletin that may come with this part
(part #00702534).  I was wondering if you guys have any suggestons or would have a way to get that or any applicable service bulletin?
Thanks,
Chris
kuds30ixbl0 Kitchen aid dw moisture inside door
25 August 2014 - 04:34 PM
hello,
Thanks for taking the time to read this.  We have run into a"newer" model kitchen aid dishwasher model kuds30ixbl0 that shows evidence of excessive moisture inside the door and around the control panel.  The customer even states she has noticed moisture dripping from around the handle.   Was wondering if there were any service bulletins or if you guys have an thoughts.  The vent assembly and associated gaskets all appear fine.
Thanks
 Chris
maytag ref mtb2156bea defrost drain issue
20 May 2014 - 11:52 AM
hello,
I've got a maytag ref model mtb2156bea.  When the unit defrosts the water misses the drain cup made into the control box.
We think there may be a funnel kit that extend the opening form the freezer further down that may correct this issue with this model. Anyone heard of this one or know a part number?
Thanks
Chris
Need help getting into a whirlpool ref dispenser
22 November 2013 - 06:17 PM
I am trying to replace the electronic paddles you push you glass against to get ice and water.  I can figure out how to remove the dispenser housing.  Please Help.  the model i GI7FVCXWA00.  I am afraid I may break something.
Thanks,
Chris
