dekostop
Member Since 25 Sep 2009
Offline Last Active Sep 10 2014 12:24 PM
In Topic: Frigidaire FGES3075KWA Range Cooking element issues
16 March 2012 - 09:54 PM
fyi...... i replaced the UIB (user interface board) that fixed it.
In Topic: GE dw auto soap dispenser part# WD12X10251 drips soap
16 March 2012 - 09:49 PM
i never ran into this problem...however thats what i would do. i have worked on quite a few of those units for other issues and none of the cust. actually used the dispenser.
13 March 2012 - 07:52 PM
tried it again...now the link works....... but would like to have some more input about the range problem...anybody ran across the same thing ?
In Topic: GE refrigerator GSH22JSTA-SS ice buildup by the condenser
13 March 2012 - 07:27 PM
could also be the evaporator thermistor or the safety bimetal.
In Topic: Thermador DW246US/U12 Dishwasher; Fills, doesn't start wash cycle
13 March 2012 - 07:13 PM
sounds to me like a stuck washpump due to non use.......
remove the filters in the tub. go inside with a finger and feel on the right hand side....you should find a round opening. that is the inlet to the washpump....take an 8mm nut driver deep into the hole until you hit something....this is the wash impeller...it has an 8mm nut. turn the nutdriver a few times until you feel the resistance getting lighter. you just freed the washpump...should be working ok now.
