dekostop
Member Since 25 Sep 2009
Offline Last Active Sep 10 2014 12:24 PM
#227156 Frigidaire FGES3075KWA Range Cooking element issues
Posted by dekostop on 16 March 2012 - 09:54 PM
fyi...... i replaced the UIB (user interface board) that fixed it.
#226922 Thermador DW246US/U12 Dishwasher; Fills, doesn't start wash cycle
Posted by dekostop on 13 March 2012 - 07:13 PM
sounds to me like a stuck washpump due to non use.......
remove the filters in the tub. go inside with a finger and feel on the right hand side....you should find a round opening. that is the inlet to the washpump....take an 8mm nut driver deep into the hole until you hit something....this is the wash impeller...it has an 8mm nut. turn the nutdriver a few times until you feel the resistance getting lighter. you just freed the washpump...should be working ok now.
