brownchristian
Member Since 12 Oct 2009
Offline Last Active May 01 2011 04:47 AM
In Topic: New Front Load Washer & Dryer
24 March 2011 - 11:19 AM
This is all I find on their website.
Sears Item# 02640272000 | Model# 40272
My link
In Topic: GE TBX25PR Refrigerator not cooling
07 June 2010 - 06:14 AM
It's located in the garage and it is summer time here in Texas.  Been in the low 90's for two weeks already and only getting hotter.
07 June 2010 - 03:17 AM
After running all night undisturbed the fridge temp is +/- 38 degrees.  So I assume all is good and the defrost is the culprit.  Gonna tear into it this week and see if I can determine the problem.
How long should I expect it to freeze back up?
06 June 2010 - 04:11 PM
Fridge has been running for 6 hours now and the freezer is 5 degrees but the fridge is only 47.  How long should I expect the fridge to cool down?  What is the correct temp?  I assume 37 - 40 degrees.
Before I start tearing it apart I want to be sure the defrost system is the culprit.
06 June 2010 - 11:19 AM
Alright defrosted the freezer over the weekend while we were gone.  Plugged it back in an hour ago and it is cooling down.  Gonna check the temps in a few hours.  If it gets cold then I want to try and fix it. How do I determine which part is broken?
