zold
Member Since 31 Oct 2009
Offline Last Active Mar 17 2015 07:48 PM
Frigidaire LTF2140ES0 Won't Drain, Pump Out
12 April 2012 - 11:55 AM
After a bit of reading on this site, (thanks so far!), I was able to take my evil Frigidaire LTF2140ES0 apart and get the pump out. The only issue I found was some quarters in the rubber sump in front of the pump, (so I'm ahead 75 cents for now), but couldn't find a filter to clean or any other obstructions in the draining system. Could these tarnished quarters be the culprit or should I double check somewhere else in the system? Also, I can stick my finger into the pump and spin the impeller all the way around, but there is a point where I have to push harder to get it to turn. It isn't rough or grindy, but more like I'm pushing against a magnet. Is this normal? Thanks!
York H2RC048S06A Fan Needs Push, But Already Replaced Parts
12 April 2012 - 11:43 AM
I have a York H2RC048S06A that has been acting up. I replaced the outside fan motor and the relay switch under the side panel last year, which brought it back to life for a season. Now, the compressor comes on and it blows cold air, but I have to run outside and give the fan a push with a stick every time to get it going. After giving it a push, it runs fine. But. I just replaced the dual run capacitor and start capacitor under the side panel with new parts this week, but I still have to give the fan a stick push to get it to run. Nothing is making any funny noises. I'm at a loss as to what the next troubleshooting steps should be to get this thing going again.
York H2RC048S06A Fan Issues
29 September 2011 - 03:12 AM
The fan on the York H2RC048S06A outside my kitchen window started makes strange noises when it ran. I followed some troubleshooting advice and could feel the blades not turning well on the fan motor. I was able to oil the shaft up a bit and it ran like a champ for about another week, then started getting noisy again. I ordered a replacement fan motor, same model, so it was an easy swap. I went ahead and changed out the run capacitor and the relay right next to it, as the top of the run capacitor was starting to get a bit oily.
Now, with all the new parts in, when I turn the A/C on inside the house, the compressor outside will come on and get warm, but the fan doesn't move an inch. I can push the blades on the fan around with a screwdriver and it isn't any easier or harder to turn than usual. What are the next steps in getting this thing up and running again?
Thanks!
