Froonium
Member Since 18 Nov 2009
Offline Last Active Jan 27 2012 01:52 AM
In Topic: Whirlpool E1F30LD035V water heater no hot water generated
26 January 2012 - 06:08 PM
You'd think so, but heating it ain't. Any ideas?
In Topic: Frig. FWT645RHS0 timer question
25 January 2011 - 06:56 AM
Borrowed a multimeter and tested the reed switch. It's working fine as far as I can tell.
20 January 2011 - 08:40 AM
Okay, I've washed the past 3 or so loads with nary a hiccup. While this is a good kind of annoying, it's still annoying.
16 January 2011 - 06:41 PM
It seems to be a random thing when it cuts off. I see the door lock light go out and it stops doing whatever cycle it was going through. I get up and jiggle the knob and it restarts. It sometimes stops again after said jiggle or it goes on and finishes without another hiccup.
16 January 2011 - 06:28 PM
I kinda figured that one out. What's causing the thing to crap out though?
