refrigerationbob
Member Since 26 Nov 2009
Offline Last Active Apr 16 2015 08:04 AM
LG RANGE MODEL #LDE3037ST BLOWING THERMAL FUSE DURING CLEANING CYCLE ON LOWER OVEN
25 March 2015 - 12:39 PM
I HAVE A LG DOUBE OVEN RANGE THE THE LOWER OVEN IS BLOWING THE THERMAL FUSE ONLY DURING CLEANING CYCLE. MODEL #LDE3037ST.
ANY SUGGESTIONS?
SAMSUNG RS263TDBP REFRIGERATOR SIDE WILL NOT COOL
14 August 2014 - 11:33 AM
I HAVE A CUSTOMER THAT HAS A SIDE BY SIDE SAMSUNG RS263TDBP, THE FREEZER COOLS FINE BUT THE REFRIG SIDE DOES NOT. I CAN'T HEAR A THE EVAP FAN RUNNING EITHER IN THE REFRIG SECTION. CUSTOMER TELLS ME THAT WHEN NEW IT HAD SAME ISSUE AND HAD A SENSOR REPLACED THAT WAS IN THE REFRIGERATOR. HELP.
whirlpool WFW9150WW01 WAHS LIGHT BLINKS TWICE AND BEEPS
06 July 2014 - 03:03 PM
WHIRPOOL DUET WFW9150WW01 IS LOCKED OUT, WHEN STARTING CYCLE ADD A GSRMET LIGHT COMES ON THEN WAS LIGHT BLINKS TWICE AND TRREE BEEPS, THIS CONTINUES ON.
ASKO WM44 / W620 MOTOR Will NOT RUN ON WASH OR SPIN
16 January 2014 - 08:41 PM
I HAVE AN ASKO MODEL W620 WM44 WILL NOT RUN ON WASH OR SPIN, WASHER FILLS THEN ADVANCES TO S ON TIMER ON ANY CYCLE. REPLACED MOTOR WITH NO HELP NOW IM SHOOTING FOR THE TIMER. ANY SUGGESTIONS? MAYBE DOOR LOCK SWITCH? DOOR DOES LOCK.
ASKO WASHER WILL NOT SPIN
06 August 2013 - 05:20 PM
WORKING ON AN ASKO MODEL # WM44 FRONT LOAD WASHER, IT WILL GO THRU ALL OF THE CYCLES BUT WILL NOT SPIN. IT DOES CLEAN THE CLOTHES AND DRUM MOVES BACK AND FORTH BUT WILL NOT EVEN GO INTO A FORCED SPIN. ANY SUGGESTIONS?
