blockisle9
Member Since 27 Dec 2009
Offline Last Active May 19 2013 06:48 PM
In Topic: GE Dryer, DDE5100RALWH Heating element.
16 May 2013 - 08:39 PM
The first part of this video shows basic teardown for this dryer.  Piece of pie, tovarish!
Yikes! That is way more than the last one I did..
I didn't see the locations of the t-stat or safety?
16 May 2013 - 08:30 PM
have you checked the voltages at the Dryer Cord Terminal Strip ?
Yes I have both legs hot, 220 volts
16 May 2013 - 05:08 PM
Thank you very much!
I will go with the easer option..
The last one I did for another friend was very easy, right on the top. This sounds more involved, how much has to disassembled to get to it?
I haven't checked the thermostat or the high safty yet, I just assumed it was the coil but I will check them first.
Are the easy to get to, to check them? Were can I located them on the dryer.
Sorry for all the questions??
Thanks again
In Topic: GE Bottom Freezer Refridgerator 7 years old freezer cold but refrigerator warm
15 January 2012 - 12:33 PM
Thank you.
I did not see the timer when I had the freezer bottom off. Did I just not see it, or is it located someware else? Its hard to tell in that diagram.
Thanks again.
15 January 2012 - 11:30 AM
Im sorry, for the lack of information, I started a new topic.
Please delete this topic if you feel the need.
Lenny
