GreenestOne
Member Since 04 Jan 2010
Offline Last Active Dec 25 2014 11:08 AM
In Topic: Maytag gas oven MGR5752BDW
02 November 2014 - 09:52 PM
How can I get this tech sheet?
In Topic: whirlpool estate electric clothes dryer EED4400YQ0
02 November 2014 - 06:34 PM
It is VQ0. So to answer Shogun, it appears that with the switch itself showing continuity when pressed on, the terminals on the start windings should show a resistance of 2.4-3.8ohms.(That is under load).
Likewise the terminals on the run windings should show aresistance between 2.4-3.6 ohms under load.I would guess that every other part needing to show continuity checked out positive, then one of those sets of windings on the motor are kaput.
Oh then there is always the door switch.
02 November 2014 - 04:24 PM
Yes, sorry for not being more specific. Flame comes on and stays on but the oven never reaches the temp you set it to reach.
Owner says usually 100 degrees less. I am going tomorrow to check specifics actual temp difference)
She is using the oven but baking isnt dependable because of actual temp isnt accurate.
In Topic: GE Microwave oven PT970SR2SS
05 August 2013 - 08:09 AM
will check, thanks!
In Topic: Jenn-air wall oven svd48600 flashing error code f-3
26 April 2013 - 05:44 PM
Thank you Samurai for the manual.
