acadiel
Member Since 10 Jan 2010
Offline Last Active Jul 11 2015 11:31 PM
In Topic: Bosch Ecosense dishwasher SHE6AF06UC error E24 and E21
21 July 2014 - 06:47 PM
Hey, I just did this one with the E24 code, if it is pumping out fine and does it in the first 2 minutes replace the lower board on the bottom right of the unit. That is the issue.
You might be on to something here.  i just found this:
http://www.designnew...p?doc_id=270603
I'm wondering if a lot of people are having these issues; I have had for a while.  Blew out the drain hose (no problems there), replaced the drain pump, checked for obstructions over and over, and I, like the OP, can only avoid the E:24 by opening the door within the first minute and shutting it again.
In Topic: SHE6AP02UC/05 Bosch infuriating E:24 drain error
12 November 2013 - 06:29 PM
Just wanted to come back and say the RepairClinic pump fixed it! Thanks! Sent from my iPad using Tapatalk HD
05 November 2013 - 10:07 PM
Thanks, Samurai -
I went ahead and ordered the drain pump from Repair Clinic.  I Googled around the stash and it looks like you just twist it counter clockwise after removing the wiring to remove it.  In the meantime, if I do the 20 minute or so Customer Test Program and get a 0 error code, I can get it to initiate a regular load right afterwards, so I'll keep doing that until that no longer works.
Thanks! :)
In Topic: Bosch Dishwasher E34 error, won't cycle unless I vacuum sump
05 November 2013 - 09:26 PM
What do you mean, "bypass the error and continue to run" - I usually still see the E24 if I open it and close it back :)
I'm only able to get mine to run at this point in the customer service test mode (which it exits with 0).  I guess it's time to try a drain pump....
In Topic: GE TFX22ZPBEWW Ice dispenser auger not going
20 May 2013 - 09:41 PM
Just as a follow-up...
I wound up getting one of these from eBay (I don't know how, but it was only $45, and the date code on the box said April 2013).  Replaced it, and all is well.
Previously tried replacing the relay on the old one; no dice.  My hunch is that it's one of the diodes or the transistor that's malfunctioning.  I might just start testing those components because a board that simple isn't going to get the best of me... all the darn thing has is two switches, resistors, capacitors, diodes, and a transistor.
