DIAMOND GAZZA
Member Since 11 Jan 2010
Offline Last Active Aug 24 2014 02:33 AM
In Topic: Overstuffing Washing Machines
05 July 2011 - 09:43 AM
Here is a sneaky way to get your point across, Disable the machine somehow (safely) and when she says its not working, test the machine. The fault will be overloading and the part will take a couple days to get here. When she is out, "fix" the machine and say it cost $100. Do this until she stops overloading it, costing $100 each time. Drop hints that the money could be spent on nicer things for the family or her. hehehe :devil:
In Topic: F & P GW611 excellence washing machine
03 July 2011 - 02:54 AM
Also, there may be something stuck in front of the pump between the two bowls. Remove the inner bowl and check, it could be slowing drain capability of the pump. Maybe a sock, sometimes I find paper money or plastic wrappers.
In Topic: New Defective Customer
28 October 2010 - 06:55 PM
free bleach???? he should bottle it and sell it.
In Topic: Fisher & Paykel washer GW701-U diagnosis help required
18 June 2010 - 07:39 PM
To set the size switch turn the power on at the power point and off at the console. Press and hold the
TEMPERATURE UP button then press the POWER button. Smartdrive will give 4 short beeps and the
pattern of LEDs will change. then press either of these that to set depending on kg your wm is on back.
• Press TEMPERATURE UP button, the COLD LED is on for 5-5.5kg (560mm wide).
• Press WATER LEVEL UP button, the LOW WATER LED is on for 6-6.5kg (600mm wide).
• Press SPIN SPEED UP button, the SPIN HOLD LED is on for 7-7.5kg (650mm wide).
• Press POWER to exit this mode.
18 June 2010 - 07:30 PM
you need to set the size of the w/m into the memory of the new board. there should have been a bit of paper with instructions how to do this in the box of the part. it wont work until you do this.
