dbirkett
Member Since 19 Jan 2010
Offline Last Active Oct 19 2012 11:04 PM
In Topic: digital manifold guages
19 October 2012 - 10:58 AM
I just use analog, don't have to worry about a little water, have a separate temp meter and p/t chart to do superheat/subcool
In Topic: Digital multimeter recommendation?
19 October 2012 - 10:56 AM
Fluke 87v and a fluke i200s current clamp, can clamp the wire and have about 5 feet of cable to the meter, it also fits in those small spaces nice
In Topic: My Miele Solaris died. How to test the motor for power, etc.?
19 October 2012 - 10:51 AM
depends on the model fluke, but make sure you have the right terminals hooked up (common and voltage AC, not Current), and switch the dial to the V~ symbol, start probing it. Most modern flukes are auto-ranging, so no need to worry about that
In Topic: Rheem 21vp50e-1A need owner's manual to change sacrificial rod
19 October 2012 - 10:42 AM
Should just look like a plug in the top of the tank, unscrew it and take a look
In Topic: Nothing but sound, not even any fury!
19 October 2012 - 10:27 AM
The user manual says one thing and the furnace data plate says another. You're shocked, I know.
Truly, I can't find any pressure switch on the PartsDirect parts list.
Gotta be there. If it was a bad inducer you'd hear it or smell it.
I've seen the inducer break at the hub, or come loose from the motor shaft, so the motor runs but doesn't induce a draft, and they won't even try to light then
