kharms
Member Since 26 Jan 2010
Offline Last Active Aug 30 2014 07:55 AM
Whirlpool EB22RK inside lights don't work. Need wiring diagram
23 August 2014 - 09:28 PM
Have a long running Whirlpool EB22RK, and the internal lights quit working.   The bulbs are good, as I tested them in a lamp socket.   The switches  are good, as I tested them with a multimeter, so isuspect a bad ground or connection somwhwere.  Where can i get a schematic/wiring diagram of this unit?
GE spacemaker JVM1860WD0002 no lights but works fine
18 April 2014 - 08:35 AM
I am the homeowner, and I replaced the over the stove bulbs on this unit a few days ago.  I returned later and they were burned out.  The inside light was also out, but had worked before.   Everything else functions normally that I can tell.  it heats up, etc.  I did make the mistake of replacing the bulbs while the light switch was on, and probably the mistake of using 20W bulbs instead of 10W.  Stupid mistakes made when getting into a rush.  So what are some possible things I did or need ot fix to get the lights working again?
