jedhaft@live.com
Member Since 13 Feb 2010
Offline Last Active Nov 03 2013 11:10 AM
In Topic: Kitchenaid KGSS907SSS
24 November 2011 - 04:03 PM
I can only assume they did run it because the door was locked the first time I looked at it. The power is ok 120 volt. No other recent trouble with voltage spikes etc. It is only happening when the self clean is run.
23 November 2011 - 09:17 PM
Its the transformer, I tested it. Do you think the heat from the clean cycle is actually burning the primary winding of the transformer? Or could there be some other cause. The secondary windings are intact. The transformer is even mounted to a small raised plate so air can flow around it.
