jimklo
Member Since 25 Feb 2010
Offline Last Active Feb 12 2015 08:21 AM
In Topic: Whirlpool Duet Front Loading Washer WFW9550WU False Starting
11 February 2015 - 12:13 PM
Thanks, with the first one being the most recent.
A web search tells me it is a water supply problem, but I'm wondering how would that cause the symptoms observed in the video before the washer even starts filling?  Now I'm starting to believe it may be a loose connection somewhere.
The F34 I can explain as a sock left in the drum before a cleaning cycle, but that was a couple of years ago.
Is there a way to clear out the error code memory and start from scratch?
11 February 2015 - 08:35 AM
As suggested, I ran through the diagnostic test yesterday evening.  It's been a while since I'd done this, and I was surprised at the number of codes displayed.
In order:
F20
F34
C01
C07
C00
H01
U15
U14
U00
H01
C00
n00
nc
21
After that, all indicators lit and the unit proceeded through the rest of the diagnostic mode until completed and shutdown.
Doc, will I be able to play the violin after the operation?
10 February 2015 - 10:28 AM
Not since this problem started occurring.
Thank you for the reminder about diag test.  I will do so this evening when I get home.
10 February 2015 - 08:53 AM
:wallbash:
DOH!  Sorry about that.  I meant to set it as unlisted, which I've just done.
Thanks for pointing that out, Kohai.
Jim
In Topic: Maytag Oven MGS5752BDS Ignites and Heats OK, But...
04 May 2012 - 12:51 PM
Problem solved, and was indeed the ignitor. It was drawing 2.8 amps. New one installed and is drawing 3.6 on the button. Ignition and full flame in 45 seconds.
The noisy flame was caused by the air shutters being wide open. This I have to attribute to jostling during our kitchen remodeling.
Thanks again for the advice!
