herfdog
Member Since 16 Mar 2010
Offline Last Active Jul 27 2015 11:16 AM
KSSO48QTX02 freezer fan and light relay clicks on & off randomly
22 July 2015 - 06:35 PM
The freezer fan and light relay periodically click on and off at the board with the door open or closed. I am assuming it is the relay rather than the switch. I noticed two boards for this fridge #Part number: 2318054
and Part number: W10789107
. Which one has the light and fan relay for the freezer section? Thanks for your help, I do not have a schematic. Any other input is also appreciated.
KENMORE WASHER 11046752701 Sud and F35 ERROR
20 February 2015 - 07:59 PM
This washer usually faults out at the beginning of the cycle. First it will get a "sud" fault then later it changes to the F35 steam function fault. I ran a steamer function check and it said "yes" for ok. I also ran diagnostic check, everything worked ok and I could hear the steamer heating. I checked the hoses to the steamer and  what I thought was a pressure hose on the incoming side of the steamer all ok, no clogs, good connections. I also checked the pin trap, pump and drain, all ok. Any ideas on what might be going on here.
Thanks
GE fridge ZIR36NMHLH humidity
09 September 2014 - 09:44 AM
I recently repaired a leak in the sealed system due to a huge ice ball on the evaporator and low pressures, deep vacuum on low side. Before and after the repair there was a great deal of humidity in the fridge, (90%, everything is wet inside). I figured this was due to the melting ice.  I told the customer to  shut off the power and leave the door open for a few days to dry it out. Do you think any remaining moisture from the ice is causing this or is there something else I should know about concerning this fridge?
Kenmore Refrigerator 106.51183113
20 August 2014 - 09:41 AM
The Ice maker on this refrigerator is not working. I'm wondering about the emitter boards on this unit since there is no indicator light with flapper closed or open. The emitter is turned on. All ice maker components, emitter boards, everything associated with ice maker is on the  freezer door so this unit is a bit different from anything I have encountered in the past. How can I test the emitter boards on this unit and do you have any info on interpreting those test results?
Thanks
Frigidaire PHSC39EGSS0
13 May 2014 - 06:00 PM
Whenever the water dispenser or the ice maker calls for water it flows to both. The fill valves are wired and plumbed correctly however both the I/M valve and the water dispenser valve are energized when either calls for water. Also, all three valve solenoids work properly. Would this be a problem with the electronic dispenser board or the mother board or the inline diodes?
