Southern Appliance
Member Since 16 Mar 2010
Offline Last Active Feb 23 2015 06:59 AM
WB27T10289 instruction sheet
09 June 2013 - 09:50 AM
I have a WB27T10289 oven control kit without instuctions !
Does anyone have one to post ?
Thanks , Randy
WF419AAW/XAA
14 February 2013 - 07:05 AM
I need a service manual or tech sheet for a Samsung washer WF419AAW/XAA .
It displays error " tE " on startup & I can't find the thermistor on it .
The machine doesn't have a tech sheet .
HELP !  Thanks !
JennAire JMW9530DAS
17 August 2012 - 08:39 AM
Do you have a service manual for a JennAire oven JMW9530DAS ?
Thanks , Randy
Frigidaire SXS PLHS69EESS2
18 October 2011 - 08:27 PM
Hello All !
Got a call the other day on a Frig. SXS ( PLHS69EESS2 ) , He said water filter was leaking & unit would not run ?
Having seen this problem before , I asked myself why would any DUMBASS design a refrigerator with the water filter in the same housing as the electronic control ?
I ordered a new control ( 5303918340 ) & installed with the new wire harness .
Also let the customer know that he should let me install a filter bypass ( 241944302 ) & a inline filter that costs less than half to replace !
But , I did all this & plugged the unit back in & everything started up as it should , BUT the freezer display was showing the temp correctly & the FF display is blinking # 4 !
I have no information on this unit .
Is this something to do with the damper ?
At startup , the damper appeared to be wide open .
Any help anyone could give me on this would sure be appreciated !
Thanx in advance ! Randy @ Southern Appliance
Kenmore gas range 790.78772407
26 September 2011 - 08:25 PM
Hello everyone !
I looked at a Kenmore gas range today. 790.78772407.
It was unplugged from the outlet when I arrived.
I put power to it & the display was dark , no response from any buttons .
I unplugged it & pulled it out to get access to remove the back panel & removed the ERC & separated the boards & saw nothing unusual eg bad solder connections on relays , NO roach shit everywhere , no scorch marks etc.
Put ERC back in & everything worked , Bake & Broil , several times.
I was writing up the ticket & all of a sudden , with the range OFF the LED on the clean button lit up & the display showed 2 dashes & I could not make it go away with the stop/cancel button .
I called the customer later to quote a price for oven control & then she told me that when the problems first started , she saw code F11
I saw no codes while I was there , AND being 30 miles away It was then a good time to learn of this then , when I asked her at the time if she had seen any error codes on the display ?
But the stupid question of the day IS what does F11 mean ? I can't find that code anywhere !
TIA , Randy @ Southern Appliance
