DeeJayK
Member Since 17 May 2005
Offline Last Active Mar 02 2012 10:58 AM
In Topic: Kenmore HE3 gas dryer (110.92826102) won't start
27 February 2012 - 01:58 PM
Just wanted to close the loop on this post.
After some further troubleshooting (including the steps suggested above) I went back to the Tech Sheet and eventually diagnosed a bad main control board. This led me to remove the board, the back of which showed obvious signs that it had blown .
I replace the board and the dryer is once again fully functional.
Thanks to those of you who responded.
17 February 2012 - 10:13 AM
while someone holds the Start Switch, (any Drying Cycle)
Test for 120v AC at each side of Belt Switch to chassis (a good ground)
I assume I do this with the power plugged in, correct? Is your assumption that the issue is with the Belt Switch?
