americantradition
Member Since 29 Mar 2010
Offline Last Active Dec 05 2012 09:45 PM
In Topic: Kenmore Washer 110.83045100 will not drain or agitate or spin
05 December 2012 - 09:48 PM
 I will see how nicely rags work sopping up any drips :) Thanks for the warning
05 December 2012 - 08:54 PM
Mission finally accomplished!! Loosened up that belt, performed the test, she's running fine. Saved her again!! Thanks Cactus Bob for all that helpful advice on this last round. We are learning a lot more about this washing machine than we ever thought possible. It does have a tiny leak coming from the grommet area but I am saving that one for the next time we want to take the washing machine apart. Many, many thanks again.
02 December 2012 - 03:42 PM
Thanks for posting the pics. That is exactly what I am talking about. New problem: we installed the new drain pump and put it back together again and...nothing is moving. Is it possible to make the belt too tight? We didn't have this problem when we un-froze the drain pump before. This time, as it was going to go into spin, it started buzzing, smelled something and stopped it immediately. Went to the back of the machine and tried to make the belt move and it wouldn't budge. What's the correction for this? Thanks in advance.
02 December 2012 - 02:01 PM
Un-freezing the drain pump was a temporary measure. I ordered a new drain pump. The only connection we are having trouble with is at the bottom of the basket. How is the manifold assembly secured to the bottom of the basket? In the diagram above, this is #22, #23, #24. It has loosened from the bottom of the machine and we can't figure out how to make that connection tighter. Installing the new drain pump is no problem at all, except this connection. Thanks for any and all help you can give me.
07 October 2012 - 09:37 PM
Thank you RegUS_PatOff
