deezus
Member Since 01 Apr 2010
Offline Last Active Yesterday, 02:43 PM
In Topic: built in oven ge model jkp45wp3wg
21 May 2015 - 05:56 PM
Ive had Corecentrix send back a supposed rebuilt board that had the silicone and greasy hand prints on it.... lets just say it didn't work and I wont use them again. I just sent a Kitchenaid cb to Circuit  Board Medics(the Gemini board) so we will see, THIER turn around was 1 day. I agree with bad bake relay, but if you didn't inspect the bake element connection then I would start there.
In Topic: GE fridge Model# GSH25JFTACC
21 May 2015 - 05:49 PM
If there is frost on evaporator cover most likely a defrost issue. If its around the door bad seal or in some cases condenser fan is bad check to see if dispenser flapper is closing EVERY time and doesn't have ice stuck in it, again, there's many things that could be wrong here, we need more info to give you proper help.
In Topic: Bosch WTA3510US/10 starts and stops
18 March 2015 - 04:22 PM
240v at heater right?
18 March 2015 - 04:15 PM
No it is not. I've narrowed it down to the ntc st heater or a bad hi limit at heater even though both ohm out. Just trying to see if anyone else had this issue.
17 March 2015 - 01:20 PM
Yes, it is up but I reset it
