deezus
Member Since 01 Apr 2010
Offline Last Active Mar 25 2015 01:26 PM
Bosch WTA3510US/10 starts and stops
17 March 2015 - 10:39 AM
This unit runs and stops over and over. I have searched on the forums but no definite answer to this issue. Everything tests out fine, anyone have a answer to this?
GE Monogram Refrigerator Mod#ZISS420DRG0SS Fresh food side not cold
07 November 2014 - 02:31 PM
Hi, I tested this units damper it works fine. I tested 12v output to temperature control board its fine. What happens is the unit will display door open when its closed, it will also keep temperature displayed when it is open but both of these are intermittent. I tested door switch it is fine. When door switch is closed fan comes on and lights turn off every time but display shows door open or temp. It also opens and closes damper too. My question how to determine if it is a bad data signal from main board or temperature control board is getting signal but is bad?
One other thing, during malfunctioning display while testing, I heard a humming noise coming from display board area. Thanks I hope someone can help me asap. I already have service manual.
PS- freezer temp is fine damper is closed to ff side.
Kitchenaid MW/Oven combo Mod#KEMC377KSS03 Replacing torsion springs
29 September 2014 - 10:59 PM
I have the service manual but it doesn't show how to replace the torsion springs that stop the door from flopping down. Can anyone help me? Ty
Samsung Refrigerator Mod#RF4287HARS/XAA CANT REMOVE DISPENSER
23 September 2014 - 10:36 AM
I have the tech manual and in order to remove the dispenser display it says to remove screw at bottom and move display to the right and lift out, I have tried this over and over an cannot get it out. The service manual is not very specific, can anyone give me any help on this ? Thanks.
Kenmore Refer Mod#795.79782.902
06 August 2014 - 11:29 AM
Searched downloads section couldn't find manual. Thanks.
