BEdwards
Member Since 14 Apr 2010
Offline Last Active Aug 31 2015 07:53 PM
In Topic: Intermittment microwave failure to heat - GE JHP62G0M1
31 August 2015 - 10:02 AM
Measure continuity on those micro switches. Sometimes they test good just popping the button in and out but if you wiggle the button side to side it will lose continuity. Also make sure door hooks are fully engaging the switch buttons.
In Topic: Frigidaire FFHS2611LWA Evaporator replacement
21 August 2015 - 10:10 PM
Lol. Not even close. Warranty job. By the way it went pretty easy. Back up and running.
In Topic: Whirlpool cabrio model wtw1640xw3 won't spin out towels
16 August 2015 - 09:32 PM
If it is knocking and throwing uL codes, I would suspect the susension rods. Have replaced many of these for uL errors and knocking badly during spin.
15 August 2015 - 08:14 PM
The evaporator comes with a heat mat. Should I also use that heat paste around the lines where they go through the cabinet?
In Topic: Electrolux EW30MC65JS built-in oven - How to get service access to microwave...
14 August 2015 - 08:51 AM
It was a no heat. Verified I was getting my 120v to transformer and was able to check the diode and cap. Everything was good. Ohmed the mag and checked for cracks in the magnet. Everything checked out on the mag but they usually do. Went ahead and replaced mag and now it heats.
