BEdwards
Member Since 14 Apr 2010
Offline Last Active Feb 26 2015 10:34 PM
LG Washer stops mid-cycle WM2031HR
18 December 2014 - 09:43 PM
Customer states that the washer will stop mid-cycle and will not do anything. They can unplug the unit and plug it back in and it continues the cycle as normal. I am thinking controller but don't do a lot of LG work. Wanted to chime in and see if this is a common problem.
Model#WM2031HR
Serial#906KWBY011597
Thanks ahead of time.
KEBS209BS01 Double Oven Blower Noise
26 November 2014 - 12:44 PM
Just bought this new double oven for the wifey. Got her all mounted and plugged in and fired up. There is almost a whistling sound coming from the lower blower. Pulled it back out and made sure none of the duct work was bent.
This is for all you WP warranty guys. Is there a known noise problem from the lower blower on these? Is there a pointer out for a wheel update or duct work update? I did some internet searching and seems a quite a few people have complained about the noise level of the fan but that specifically said a "whirling" or "whistling" sound.
Thanks ahead,
Brad
Whirlpool compressor
06 October 2014 - 08:47 PM
Anyone ever see a 2 year old machine with a compressor this rusted out and deteriorated. It was rusted so bad the the pin is gone and refrigerant had leaked out the hole.
Attached File  2014-10-06 21.17.42-1.jpg   298.84KB   0 downloads
New Appliance Service Manual added: Kenmore 110.87571603 HE2 Dryer Tech Sheet - 8572745
04 October 2014 - 08:06 AM
File Name: Kenmore 110.87571603 HE2 Dryer Tech Sheet - 8572745
File Submitter: BEdwards
File Submitted: 02 Oct 2014
File Category: Appliance Repair Manual Pot Luck Supper
PUB 8572745
Click here to download this file
Fisher & Paykel DD605 DishDrawer not finishing cycle
16 September 2014 - 07:43 PM
Got a unit that has been kicking my butt for a couple days. First went out on the call that the bottom drawer will not drain. Went through all diagnostics and everything passed. Tried three different test runs and unit drained fine every time. Pulled the filters out and the rotor and nothing in there. Thinking maybe there was a clog that finally pushed out, I left and told them to call me if problem persisted. Two days later, same problem. Unit gets stuck on rinse cycle and will not drain( about 15 minutes left on timer).
HELP!!
