fixit guy
Member Since 03 May 2006
Offline Last Active Oct 13 2013 07:22 PM
In Topic: Whirlpol cabrio WTW6600SB2
29 July 2013 - 06:28 AM
Try this, put the machine in diagnostics, turn on drain pump.  Wiggle wires at P-4 on control while pump is running.  Then wiggle wires at pump while it is running.  This is how I found problem on intermit drain several times.  Good luck!
28 July 2013 - 05:44 PM
I have seen this many times and there are several problems that can cause this,
   debris in drain hose.
   Pump.
   connections at pump or board. Wiggles wires at pump they might come right off.
   Debris under coin trap,  did you remove it?
Hope this helps!
Fixit Guy
In Topic: Work van storage
08 August 2012 - 06:39 PM
Thanks for the reply. I called AmericanVan and they don't carry the wire shelving. I know that Sears has the dealer install the shelves but I can't find the manufactor of them. This is driving me nuts!!!!!!
In Topic: WP Gold refrigerator
18 May 2012 - 08:36 AM
Thanks for the reply.j Yes I did the thermistor test before changing the control board. When I changed the thermistor and board, the control did a self test upon startup and thermistor passed. The damper was open when I left the house and now I am thinking damper problem?
In Topic: Kenmore 795.75283401
06 October 2011 - 09:40 PM
It sounds like it is going into the demostration mode accoring to the manual. Maybe something in the door holding the keypad down?
