LLAMBERT
Member Since 01 May 2010
Offline Last Active Feb 01 2015 05:14 PM
Whirlpool WRF990SLAM00 refrigerator. saga,Did dispense ice before installation of heat...
13 November 2014 - 05:56 AM
So I installed the heater kit and now the ice wontcome out od the door. ANY ideas?
WRF989SDAM02 ice under freezer evap fan. service bulletin/WHIRLPOOL
27 August 2014 - 07:28 PM
block of ice  on top of evap, under fan. i am a bit puzzled, changes fan motor as it includes thermistor and deprost terminator. i cant be the only one running into this
VamPLIERS anyone use them?
20 August 2014 - 08:31 AM
supposed to get out an stripped or rusted screw or bolt.
Frigidaire ref. DGUS2645LF3 stuck in Sabbath mode
14 April 2014 - 07:35 PM
So. Sb Sb , user manual says to push a particular button down for 5 seconds, try and try, no soap, no radio.  Thinking
Module dispenser PART NUMBER: 242115004
Also thinking, "not cheap", plus thinking "probably harder to change than it looks" Any one have a bit of experience on this beast to light my way through the forest?
795.77563600 ER/IF ?
28 March 2014 - 05:26 AM
OK. i
Iknow this is the icing fan error code, Probably all I need. but I see then fan is running when I have it partially removed, still no cooling to the icemaker. fan running slow?
