Chat_in_FL
Member Since 16 May 2006
Offline Last Active Yesterday, 05:13 AM
In Topic: GE Microwave JEB1095SB001 running, not heating
29 July 2015 - 05:51 AM
Have you seen magnetrons fail within two years?  I had mine replaced last time around at a shop.
TIA
scuba415
I've seen a loose connection at the magnetron terminals that gave the appearance the magnetron was failing several times...
In Topic: KENMORE 66516529000 Dishwasher lower rack
16 July 2015 - 06:35 PM
Sorry, but I have to ask the obvious... are you putting it in backwards? (won't fit backwards)...
In Topic: Kitchenaid oven buzzes when you turn off oven
15 July 2015 - 05:34 AM
Full model number? (31) results found for Model #KEBC177
Cooling fan running?
In Topic: Bosch Dishwasher SHE55M16UC/64 Burnt Terminal
12 July 2015 - 03:14 PM
I suspect the hot wire was connected poorly and came loose causing arcing and the meltdown but I'm not 100% sure of that.  What else should I check before I replace the terminal block and hook the washer back up to power?
Thanks for your help.
Loose connections will overheat and burn. I would not over-think this one too much and simply replace the terminal block and connectors.
In Topic: LMV1630WW LG Microwave trips circuitbreaker
09 July 2015 - 12:29 PM
Check for insulation breakdown in the HV section, especially in the wires to the magnetron, could be arcing to the case and tripping the ckt bkr. Have seen that more than once.
